what plugs??
brunolund
i've got a 96 merc 4.3, which i have changed to one from a 90 jimmy.
what plugs should i use for this set up? not sure if the automotive ones would be the same as marine. i'm using the ignition from the 96, but the motor is a 90.
Re: what plugs??
Ayuh,.......
AC Delco, MR43T............
jacko137
Re: what plugs??
Sorry to jump thread, but I figured Bondo might be able to help me as well.
I have a 1977 mercruiser 4cyl 120 serial number 4511xxx. It is always referenced by hp, so I don't know if this is a 2.5 or what.
I changed plugs this weekend and Napa had Champion plugs that fit. Are these ok or should I get Delcos?
Thanks Bondo (or anyone else that wants to chime in)!:redface:
Re: what plugs??
Ayuh,.... I prefer ACs,.....But it's Your boat.....
Don S
Re: what plugs??
And just why couldn't you start your own thread????
