  #1
Old May 30th, 2008, 12:21 PM
hckrphil hckrphil is offline
Question Mercury Sportjet 90 - Hard Starting
I just rebuilt my Sportjet 90. Its takes a bit to get it to start....... basically, one person turning the key and me flubbing with the throttle on the engine. It fires, then dies. Fires then dies........ fires then dies.......But, once it starts, it runs nice and strong.
Right now I have the oil injection connected........ as well as a 50:1 mix in the tank.
Would the access of oil be causing the rough starting? What else should I look at?
Thanks aton!
Phil
  #2
Old May 30th, 2008, 01:45 PM
ddennis's Avatar
ddennis ddennis is offline
Default Re: Mercury Sportjet 90 - Hard Starting
Possibly..but considering it was just rebuilt....did you (or your mechanic) do a proper link and synch on the carbs/timing? Sounds more likely...
  #3
Old May 30th, 2008, 02:35 PM
No I have not. I followed the manual for adjusting the carbs....... I have the procedure for checking the timing at WOT (seems weird...... so I'm supposed to tie on to land and hten punch the gas wide open????)
Not many people if ANYONE around here even work on sportjets.......
What do you mean a link & synch?
Quote:
  #4
Old May 30th, 2008, 04:12 PM
ddennis's Avatar
The opening of the carbs has to be in synch with each other as well as in synch with the timing advance. It all has to work together in perfect mechanical harmony or it won't run right. All carbs have to open the same amount at the same time, while at the same time the linkage has to advance the timing the apropriate amount. The procedure is outlined in the service manual. Sportjets are the same as any other outboard till you get to the lower unit. your 90 is actually a 115 powerhead if I understand them correctly...
  #5
Old May 30th, 2008, 04:29 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
What parts did you use for the rebuild? Remember a 90 Merc Sportjet uses a Force powerhead with Mercury ignition........Mercury 90 hp outboard powerhead parts won't work.
  #6
Old May 31st, 2008, 01:32 AM
Once its running it runs good. Its just a matter of starting it after its been sitting for a bit.......
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hard starting 2002 Mercury 90 Saltwater ELPTO borskislider Mercury & Mariner Outboards 2 February 26th, 2004 05:02 AM
Mercury SportJet 90 Stalling jetdriven Mercury & Mariner Outboards 31 December 8th, 2003 01:17 PM
Mercury Sportjet 90 won't start dannypz Mercury & Mariner Outboards 1 August 18th, 2003 08:03 AM
1986 90 hp mercury hard starting when warm jim short Mercury & Mariner Outboards 2 June 27th, 2003 07:47 AM
MERCURY SPORTJET 90- 1996 gyo taku Mercury & Mariner Outboards 2 July 25th, 2002 08:59 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
