chaddemler1980
- Mar 4, 2008
- 69
i have removed most of the teak trim from my boat already but i am running into a problem with removing a few larger pieces of the base trim on the outside of the boat. the problem is the screw holes are "capped" off by teak wood fill caps... is there a way to get them out other than destroying them to get access to the screws underneath? if not what is the best way to get them out? i heard using a drill bit and drilling them out? if i do that where do i get new ones to cover the screws when i reinstall them? i have already tried prying them but it seems as tho they are glued in or really wedge in tight.
