  #1
Old May 29th, 2008, 03:56 PM
hobiecat hobiecat is offline
Default Evinrude - Ignition Switch????!
I'm hoping that one of you guys might be able to help me out...
I've got an '87 60hp Evinrude (E60ELCUC). Last year I was having problems with the Starter motor staying on after the key had been released and even turned off. In fact, I burned up and replaced a starter. I assumed this was a problem with either the ignition switch or the starter solenoid. Since thet are both relatively inexpensive, I decided to change out both and be sure I got the problem taken care of. I bought an ignition switch off of Ebay that was supposed to replace many different models, mine included. When I received the ignition switch I notice that the terminals on it were marked a little bit differently... the original had six terminals marked; M-motor, M-motor (raised), B-battery, S-solenoid,C-choke, A-accessory... the new switch also had six terminals but they were marked; M-motor, M-motor (raised), B-battery, S-solenoid, C-choke, I-ignition. after some research, including talking to my local dealer, I came to the conclusion (wrongly or rightly) that the I and A terminals were interchangeable. So, I hooked the wires that would normally be hooked to the A terminal to the I terminal. After getting the switch in, I tried starting the boat... nothing. I don't even hear a click from the solenoid.
So, my questions are...
1.) Do you think I've got the wrong switch, even though I've been told otherwise?
2.) If the switch is wrong, is there a chance I fried something else... if so, what?
3.) If the switch is right, where do I start?
4.) This maybe a stupid one... if the switch is right, is there a main fuse that may have blown?
Right now, I'm thinking I should just order a switch that I know is correct, install it, and go from there.
Any help would be greatly appreciated.
  #2
Old May 29th, 2008, 04:23 PM
Randyg123 Randyg123 is offline
Default Re: Evinrude - Ignition Switch????!
I hate to ask the first question that came to my mind, but did you disconnect the battery when you re-wired the switch? If so, is everything hooked back up? There is probably a fuse on that line. Mine is an in-line fuse up by the solenoid.
  #3
Old May 29th, 2008, 04:39 PM
Yeah, I hooked everything back up... or atleast I think I did. I attached all the wires to the ignition switch and hooked up the two main battery cables. Would I need to hook up more??
  #4
Old May 29th, 2008, 04:52 PM
ezeke ezeke is offline
The raised M is the black and yellow kill wire running to the power pack. The other M is the black ground wire coming from the engine block.
The fuse is a short 20 AMP fuse in a holder off the solenoid's incoming large post.
Here's a link to a thread with diagrams, scroll down to find the wiring:
http://continuouswave.com/whaler/ref...ionSwitch.html
  #5
Old May 29th, 2008, 05:39 PM
I have everything hooked up right according to the article. Also, the article seems to indicates that the A and I terminals are interchangeable as well. Is this the case? I just want to make sure that I'm not p***ing up a rope here with the wrong switch. Is there any difference in the A and I terminals? The switch I have has spots for an A terminal and an I terminal, but only an I terminal in place... why would they do that if they are interchangeable????
Sounds like I need to look at that fuse when I get home tonight.
  #6
Old May 29th, 2008, 10:15 PM
F_R F_R is offline
The switch is correct. You may have a problem with the start-in-neutral switch. Or you have the wrong solenoid or wired incorrectly.
  #7
Old June 2nd, 2008, 11:01 AM
OK, as ezeke stated the issue was a blown fuse. It's running great. Thanks.
Now I have another problem... It won't shut off with the key. If I pull the emergency kill switch (kanyard) it shuts off, but if I turn the key off and even take it out it just keeps running. This just started after replacing the following; starter solenoid, rectifier, ignition switch. The starter solenoid and rectifier I hooked up exactly like the ones I took off. The ignition switch is hooked up like the diagram in the article linked here.
Any ideas why it would be doing this???
  #8
Old June 2nd, 2008, 11:13 AM
Both the ignition switch and the lanyard switch share the same black with yellow kill wire (large M), and are grounded to the same black ignition ground (M). The rest of the wire must be good or the lanyard would not work.
Run your ohmmeter from M to M on the ignition switch. You should have a reading when the switch is off and none in the run position.
  #9
Old June 2nd, 2008, 01:37 PM
Thanks, ezeke. I figured the lanyard and the key shared a common circuit, and since the switch is practically brand new... that is what has had me scratching my head. I will check the switch tonight when I get home.
  #10
Old August 8th, 2008, 10:53 PM
bryan1234 bryan1234 is offline
so what happened
i got the same problem
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
135 Evinrude Ignition switch BagOFchips3071 Johnson & Evinrude Outboards 21 March 22nd, 2007 05:32 PM
Ignition switch wiring, 97 Evinrude bilehuwh Johnson & Evinrude Outboards 5 September 3rd, 2005 07:07 PM
evinrude ignition switch xskater23 Johnson & Evinrude Outboards 4 December 6th, 2004 04:41 PM
ignition switch for 1998 evinrude 90 worthit Johnson & Evinrude Outboards 2 August 4th, 2003 06:52 PM
evinrude power pilot ignition switch chas Non-Repair Outboard Discussions 1 July 20th, 2003 06:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
