Re: Damaged prop
You can order a new prop from I boats Marine Store. Just click the link at the top of the page. You can get a hub system prop (two piece) or integral hub (one piece) prop. Choice is yours.
A deep socket will work to remove the prop nut. Getting the prop nut cotter pin out is sometimes a pain, its very close quarters in the 50hp. And the cotter pin is stainless. So replace with the same, or use a locking prop nut with the plastic insert at one end.
I have bent aluminum props on my 40hp Evinrude. I put them in a vice and using wood plocks and hammer carefully straighten them out. A little heat from a propane torch won't hurt either. Remember, your only running a 50hp, not 200hp, so the chances of breaking a straigntened prop are not as great.
If you boat in an area where hitting obstructions and damaged props are common, think of using a hub system. It saves money after the first prop. I use the Hustler brand hub props on my 40hp. They are good props, good performers with cupped edges, and inexpensive. I nave no complaints.
