  #1
Old May 29th, 2008, 08:43 AM
Nandy's Avatar
Nandy Nandy is offline
Default Evinrude 70hp 1975, new pump, no water.
Model 70573-b, serial J0001631. I replaced the pump with the new improved pump, did a carb job and installed a new thermostat. I attached the water muff and fired the motor. I was a little apprehensive as this motor does not have the telltale stream of water. I kept feeling the motor until it got a bit more than warm to the touch than what I liked. I killed it and took the thermostat cover out. Much to my dismay the thermostat was dry and there was no sign of water anywhere.
First I thought since I have well water where I am working the motor maybe the low pressure was not helping the pump. But I could see how the amount of water escaping around the water muffs was a significant less than when the motor was off. I also noticed a lot of water coming off those vents a bit higher in the lower unit.
I am theorizing that maybe the pump case did not set up right in the water tube and that is my problem. If not then something is plugging the water tube or another section of the water jacket. If I dont see anything wrong with the pump or the connection from the water pump to the water tube then I will use an old cut water hose attached to the water tube to see if there is water flowing to the water jacket then. If I still dont have water it must be something in the water jacket/tube.
Anything else that you guys think I should check? I have changed plenty of impellers so I am sure I have the impeller blades fold correctly but I will check that too.
Thanks!
  #2
Old May 29th, 2008, 09:52 AM
Reggie08's Avatar
Reggie08 Reggie08 is offline
Default Re: Evinrude 70hp 1975, new pump, no water.
I have no expertise with motors but I had a booger of a time getting my water tube to insert properly into the water pump. The rubber gasket would fold up once I started to slide the lower unit back in. I eventually put some WD-40 around the inside of the rubber gasket and left it sticking out about halfway. Once I made sure everything was lined up, I carefully slid the lower unit in the rest of the way. I would check that first personally.
  #3
Old May 29th, 2008, 04:11 PM
Nandy's Avatar
The problem was the pump not aligning with the water tube. I fixed that and it worked. I proceed to do the tattle tale retrofit as this motor dont have one. I mounted the connector in the thermostat cover in the section where the water comes from the motor. The water is very hot there. If I looked closely I could see the steam coming out of the water. However, I could touch the stream with my nitrile (sp) gloves and no problem. It was a little hot in the bare skin though. Also I kept touching the motor all over and it would take from 6 to 10 seconds before it was a bit uncomfortable to the touch. Does anyone knows if it will be an issue to have the water connection there? I was planning in the future to add a water temp and water pressure gauge but I am not sure if this might have any adverse effect. Any input will be appreciated. Looks like I am going for a ride on it tomorrow...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1975 Evinrude 40hp (water pump indicator) ScttAppleby Johnson & Evinrude Outboards 3 July 29th, 2008 10:20 AM
1975 25hp Evinrude Water Pump Parts mattyv Johnson & Evinrude Outboards 2 April 6th, 2008 03:59 PM
Evinrude 1975 135hp Water Pump Stream kci5477 Non-Repair Outboard Discussions 1 September 22nd, 2005 09:48 AM
Water-pump gaskets on 1974 70hp Evinrude?? c903 Johnson & Evinrude Outboards 2 July 14th, 2005 06:05 PM
1975 evinrude water pump? pjm257 Johnson & Evinrude Outboards 4 February 28th, 2005 09:21 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
