  #1
Old May 28th, 2008, 08:55 PM
denis5893 denis5893 is offline
Default 1992 or 1993 60 hp mariner prop and water pump
hi i just got my motor and started it and it took about 20 seconds for the water to comr out and after that it worked good until i would stop the engine and started it again,the same thing appened.is this normal for these kind of engine or i should change the water pump.if so ,i would like to know where it is located i also think that the prop is to little for the engine.i have a 50 hp evinrude and the prop is way bigger.what is the normal size for the prop.thanks
  #2
Old May 29th, 2008, 12:03 AM
1ford4x4 1ford4x4 is offline
Smile Re: 1992 or 1993 60 hp mariner prop and water pump
water pumps or impellers should be changed ever two to three years every two if you run in a sandy river alot. your prop size should be around a 10 to 13 pitch and around an 11 1/4 to 11 1/2 inch diameter. you have to take the lower unit down to get to your water impeller. it usually have three bolts holding it in. one on each side you will need a open end wrench and one on the lower rear on top of the prop you will need a socket to get to that one.don't start your outboard dry the water impeller is rubber and it rides in a stainless steel housing if it is dry when you start the motor the rubber will stick to the s.s. and tear the rubber off. then you don't get the water flowing thru the motor like it should and then you get to the point where it takes 20 seconds for the water to build up pressure just to pee it out. then you get to the point where you don't have any water coming out at all.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1996 mariner 60 hp jet changeover to prop buckinbull Mercury & Mariner Outboards 1 June 2nd, 2008 10:26 AM
1996 mariner 60- water pump question bitzer26 Mercury & Mariner Outboards 4 May 28th, 2008 08:46 PM
1993 Johnson 9.9 hp - Water Pump telltale not working svenr Johnson & Evinrude Outboards 7 April 9th, 2006 05:19 PM
water pump - mariner 60 hp bech Mercury & Mariner Outboards 0 July 19th, 2005 12:52 PM
60 hp mariner water in cowling riverebel Mercury & Mariner Outboards 6 September 15th, 2003 06:32 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
