I have a 1981 90hp Johnson model #J90TLCIM. I also have the Seloc repair manual and the Clymer shop manual. Funny thing...Clymer says spark plug gap is 0.040" and Seloc says 0.030". I believe its 0.030" for L77J4 plugs? I I'm using replacement plugs L77JC4.
Seloc does not go into any detail on the emergency ignition kill switch that I can see, or in the wiring diagram but the Clymer does. It looks like the kill switch was used in 1982 and later for the 90hp. My question here is do I have the right controller and what is the 1/8" hole in the lower front portion for? When in neutral there is a plate that slides just behind the housing and when in gear, forward or reverse, the plate moves away. Just curious. Must be inside parts moving around. Thats not a kill switch is it?
On this controller I believe when you push in the key it activates the primer solenoid to inject fuel thru the crankcase into the cylinder. Well...it doesn't work but when I apply 12V to the solenoid(purple/white) I can hear the plunger pull in. If I find the Ign switch checks out, except for this issue, can I just mount a momentary contact push button switch somewhere instead of replacing the entire switch. Using manual operation every time everytime I start is a hassel cause I have to pull the cowling.
I'm just getting ready to fire it up and wanted to make sure my thinking was correct first. Anything special about the Tach to be used? All I have is old OMC tach for pre 1969 motors.
I'm not absolutely certain this controller was used for this motor. The previous owner had a 70hp and switched to a 90hp in the same year so the when I got this motor home I discovered the wiring harness had been cut out and is missing about 10 feet. Not a problem all the wires matched up.
Thanks in advance.
Thanks in advance.
