Hi, I will be taking the outdrive off for inspection of the u joints. Are there any gaskets or O rings that I will need? I am goint to just remove the outdrive from the bell housing. Thanks
When you pull ther old impellar out the blades should be bent and stay that way since its worn in. Put the new impellar in with the blades bent in the same direction. You could even put the lower unit in gear and turn the prop in the correct rotation to turn the drive shaft, this will tell you what direction the blades would be swept in when the impellar is spinning.
I didn't notice which way the blades were bent when I removed the old impeller. If I didn't put the impeller in the same direction, can this be harmful?
