  #1
Old May 28th, 2008, 12:04 AM
wargle2 wargle2 is offline
Default Mercury trim/tilt pump seized
I have a 94, 90 hp Mercury and the three ram trim/tilt system with the square, Eaton motor. The pump has locked up. Everything was good last fall when I put the boat under the shed for the winter. The motor was resting on the "transom saver". This Spring, while getting ready for a trip, the trim/tilt wouldn't move. I checked voltage, relays, etc. I removed the motor/pump there was no water in the system, but the fluid was low, maybe 1/2 to 2/3 full. I separated the motor and pump and tried to turn the pump with an allen wrench and had to use pliers and a lot of force just to move it a little. I have heard these pumps are not serviceable. Does anyone have any information on this kind of pump or where I could find a replacement, pump only? Thanks.
  #2
Old May 28th, 2008, 11:01 PM
fstrnuthink fstrnuthink is offline
Default Re: Mercury trim/tilt pump seized
I believe you have to get them from Merc.Mine had to replaced on my 200 Black Max.It took the dealer a week to get from Merc. I pick it up tomorrow.800.00.
  #3
Old May 29th, 2008, 02:37 AM
Sink_Tip Sink_Tip is offline
I just bought a complete used tilt/trim 3 ram, 3 wire, square motor with side fill for my 70hp on epay for $230 including shipping. It's nice and clean and works great. The other style with the 3 ram, 2 wire, round motor with the aft fill will fit between the brackets but you will need a relay kit to make it work properly.
You can find new replacement motors on epay for about $80 and new motor/pump cartridge units for around $200.
In my case, the PO had removed the zinc anode and the unit was used in salt so the housing was in very rough shape. I wanted to start with a nice clean fresh water unit. If you buy used get a fresh water unit and make sure to get the anode!
Hope this helps.
  #4
Old May 29th, 2008, 02:46 PM
Chris1956 Chris1956 is offline
Wargle, Arco makes aftermarket PTT motors. They are likely cheaper than OEM.
  #5
Old May 31st, 2008, 12:23 AM
Thanks for the help, guys. I will investigate your suggestions.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Loosening up a seized trim tilt on 48SPL 1989 george3405 Johnson & Evinrude Outboards 8 February 15th, 2008 08:31 AM
help with wiring old mercury trim /tilt pump goldhunter_2 Mercury & Mariner Outboards 4 May 14th, 2006 08:13 PM
help with wiring old mercury trim /tilt pump goldhunter_2 Boat Restoration and Building 1 May 12th, 2006 11:17 AM
Trim / Tilt- manual release seized Iceking Johnson & Evinrude Outboards 3 February 19th, 2006 03:45 PM
85 mercury trim/tilt pump leaking gwag14 Mercury & Mariner Outboards 0 September 8th, 2002 08:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
