  #1
Old May 27th, 2008, 09:31 PM
Fish Whisperer's Avatar
Fish Whisperer Fish Whisperer is offline
Thumbs down Evinrude carburetor needles
I just installed a carb kit on my 1968 Evinrude 3hp Yachtwin. I failed to check the needle adjustment for both high and low speed needles before disassembly. Is there somebody out there who knows the sweet spots for this carb???Thanks in advance.
  #2
Old May 27th, 2008, 09:59 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Evinrude carburetor needles
courtesy of Joe Reeves.
(High Speed Adjustments)
At full throttle, with the proper size screwdriver, slowly start turning one of the H/S needles in segments of 1/8 turn, waiting momentarily for the engine to respond, then repeat turning. You will reach a point where the engine will start to die out. At that point, back that needle valve out approximately 1/4 turn. Now, go to the other High Speed needle valve and repeat that procedure. At some point in that 1/4 turn out, you will find the smoothest high speed setting (you can now lower the throttle rpm). That will have both high speed needle valves set correctly, and at that point you can lift that center lever adjustment of that high ridge, keeping it lifted until the point is facing the engine, then lower it into its proper position. (When you turn that lever now, you're adjusting both High Speed needle valves at the same time
(Slow Speed Adjustments)
Now, lowering the rpms of course, take the engine out of gear and set the throttle just to where the engine will stay running. Again, in segments of 1/8 turn, slowly start turning in one of the slow speed needle valves, waiting a few seconds between each turning for the engine to respond. As you turn the s/speed needles in, the rpms will increase..... and as it does, lower the rpms to where the engine will just stay running (otherwise the rpms will climb quite high). You will reach a point whereas the engine will either start to die out or it will spit back (sounds like a mjild backfire). At that point, back the needle valve out 1/4 turn. Repeat the process with the remaining slow speed needle. Again, at some point in that 1/4 turn out, you will find the smoothest setting. When finished, tighten the jam nut somewhat, then remove and reinstall the s/speed knobs correctly (right side up)
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old May 27th, 2008, 10:01 PM
wbeaton's Avatar
wbeaton wbeaton is offline
TD beat me again.
__________________
Wayne
  #4
Old May 28th, 2008, 09:50 PM
Thanks for the info td. Purrs like a kitten.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mystery carb needles sikz3 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 August 24th, 2006 04:27 PM
Carb IDLE needles or no IDLE needles ss9940 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 June 3rd, 2006 11:22 AM
Where to find carb needles ? Saboat Johnson & Evinrude Outboards 4 September 20th, 2004 06:25 AM
carb needles tgissel Johnson & Evinrude Outboards 1 June 4th, 2004 12:51 PM
Evinrude carburetor D.J. Johnson & Evinrude Outboards 1 November 7th, 2003 01:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
