Re: Bow mount trolling motor?
The way mine was set up was I made a fishing platform deck in the bow seating area, I removed the seat cushions and made a template of where I wanted the deck to be, then transferred the size to a sheet of 1/2 marine ply ( you might need 3/4 if you have to span more than 15 or 20 inches)and covered it with marine grade carpet,<br />as far as mounting the entire deck, under the original cushions there were storage wells<br />and I just made some blocking cleats that "hooked" underneath the lip on the well and then bolted through the fishing deck, I also put some carpeted spacer blocking between the new deck and the fiberglass cushion ledge for wire chase and to aid in drying when things got wet.<br />The total weight of all this deck W/O trol mtr<br />was about 50 or 60 lbs. We fished with this set up for years with no problems,Although later on we did add a live well between the walk-through space.
