Hi,
I have a 1980 skeeter wrangler 16ft semi v bass boat. It has a 79' johnny 115 (it used to be a 100hp before I swapped powerheads). I'm guessing I'm looking at about 1200lbs. and it runs 44mph WOT (gps) @6200RPMs. I'm guessing that's a little high for several reasons. 1) this was measured with a full tank and 2 people, semi-rough water. 2) The prop that is on there is pretty bent up. I have no idea what prop pitch is on there right now (it is the origional prop from 79' and the stamp is worn off. It measures at around 13" wide. I need to get these RPMs down. Can anyone get me to get in the right ballpark as to where I need to start trying prop pitches? Thanks for your help.
