Cleaning Outdrive?
25thmustang
So what products do you use to get barnacles off the outdrive. We got an acid based product for the gelcoat, but it seems to be real harsh and I want to avoid using it on the outdrive if there is something better out there. So what do you guys recommend?
Thanks in advance.
JustJason
Re: Cleaning Outdrive?
5 inch wire cup brush on the end of my angle grinder..... little compressed air... wipe down with acetone, prime, sand, prime, sand, paint, sand, paint, sand, paint, sand.....
25thmustang
So the best bet is to sand it down and paint it? If thats the case, could I use the acid wash I have to get the barnacles off, then send it down and paint it up again?
TilliamWe
Banned
Acid will be fine to start with. If it doesn't take it off, you might try a Scotchbrite pad before you actually go removing all the paint.
