  #1
Old May 27th, 2008, 12:06 AM
plmbr plmbr is offline
Default Evinrude 9.9/15 Exhaust Tube
Hi all; I have a few more questions about converting a 9.9 to a 15 . I just rebuilt my evinrude 9.9, and I've found a 15 hp carb. I thought my motor was a 1990 when I posed my other questions on whether just using the bigger carb. and found out for a 90 to 92 it would as they have the same exhaust tube round on the bottom end. But since have found out my motor is a 1989 and the exhaust tube is square on the end with a gasket.
My questions are
1 - Will the square tube be sufficient to get rid of the exhaust if I install the 15hp carb.
2 - If not and I have to change to the rounded end tube of the newer model will the outer exhaust housing of my 1889 9.9 be ok, or would I have to get one of the newer models as well.
I'd really appreciate an answer of some kind as I'm anxious to get a new carb on the motor whether it be the 15 or getting another 9.9 carb motor. as the old one is cracked. Thanks ...Plmbr
  #2
Old June 12th, 2009, 11:14 AM
digitalkreation digitalkreation is offline
Default Re: Evinrude 9.9/15 Exhaust Tube
Did you ever find an answer to your question? I've got a 1986 9.9 and I'm converting to a 15. I've already purchased the carb (got 2 actually) and the inner exhaust tube, but as you have seen, it's shorter and rounded, while the 9.9 is longer, square and seals up tight at the bottom.
I'm wondering if the rounded tube is fine to just go in as it is, and not to worry about it being shorter and not sealing up tight, or if I need a complete exhaust housing to go with this inner tube I've got..
  #3
Old June 12th, 2009, 12:07 PM
Whoopbass Whoopbass is offline
Just change out the carb and run it.
I wouldn't mess with the exhaust tube besides what are you going to get .5 more hp or less with the larger tube?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Exhaust Tube vs. Exhaust Bellows MnHutch Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 July 17th, 2007 05:32 PM
1982 Evinrude 15 hp replace water tube??? rifflerunner Johnson & Evinrude Outboards 1 January 18th, 2007 11:04 PM
Alpha One exhaust bellows upgrade to exhaust tube? KarstRanger Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 19th, 2006 01:12 PM
Exhaust bellows = 2 clamps. Why Exhaust tube only 1? natwales Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 March 21st, 2006 08:52 AM
Evinrude 15 with oil and water out the exhaust. Bearcamp Johnson & Evinrude Outboards 5 June 7th, 2003 07:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
