Re: mercury 65hp steering setup??
It can be done, the only question is what stuff do you need?
Look at the motor's tilt tube. Is it threaded on both ends and hollow? If so, it is likely a standard boat steering cable (Rack and pinion or rotary) will fit without a problem. If not, you will need to buy a kit to adapt the standard steering cable to a splashwell mounting. Get on the Teleflex web site and the info should be posted, since they make all the components. It will also tell you how rto measure for correct cable length.
