how much time passed between the last time it ran well and this time?
carbs will varnish up quickly, even quicker if fuel stabilizer isnt used,
I have a few customers that dont get it so I have done the carbs every spring for almost 20 years
test spark, test compression and go fix the fuel system, I really doubt you will see a pump issue as when you prime it, it simply bypasses the pump and fills the carbs.
