WHen the motor is tilted up, it leaks fuel from below the cowling. I replaced the gaskets that go between the airbox/silencer and the face of the carbs to no avail. Also, on my airbox there is no hose connection for a return line to the intake manifold.
How can I stop this? It makes an oily mess (premix) at the back of boat.
Could it be that my floats are set too high? I dismissed this idea at first, because when the engine is tilted down and I pump the primer bulb, it gets hard a no fuel seeps out of the carb throats. Nor does fuel spill out when it's running.
Fuel only drips out, when tilted up.
