Mkos1980
- Oct 25, 2007
- 640
Recently my origional flapper pin style shutters were making way too much noise for me so I went and replaced them with the drop in Mallory units. Is there a trick on getting the flappers to have less resistance. I was able to squeeze them in but it takes some force to push through the rubber and when you pushed though to much they both went verticle and stayed there. I pryed them back up so that they would block any incoming water. After buttoning it all up, I started it up and it was quiet and water and fumes came out. I assume it was ok. Anything I should check for in the future? Does the heat and water make the ruber softer?
