'98 merc 60hp outboard/primer solenoid
hooknsnook
Got a problem moving my boat...motor starts with no problem but it will not continue running unless I continue to hit my choke switch. I was able to hold the primer solenoid in position to continue running engine. Is it possible my primer solenoid is bad? Any feedback is helpful..
Thanks!
Laddies
Banned
Re: '98 merc 60hp outboard/primer solenoid
If you need to hold the primer in for the engine to run you have a dirty carb.
