Re: Evenrude 155
Welcome to I-boats
Get a new key, install to manufacture specs including the correct torque settings, the timing is set by the flywheel key.
Have to torque to correct specs or it will keep on shearing keys. order your key or purchase from omc/brp dealer as they are hardened keys, one from auto store may not hold up in the outboard installation.
If you do not have a manual get one, it will save you $$$ in maintenance and from throwing parts at the engine.
After the flywheel is inmstalled go to the FAQ section and read Joe Reeves timing procedures to set your timing advance properly.
