  #1
Old May 24th, 2008, 03:31 PM
bostonpilot bostonpilot is offline
Default Help!! - 15hp Mariner starting problems
I'm stumped and could use some ideas from the group. I have a 1991 15hp Mariner. At the end of last season, it started running like crap. The only way to get it started was to shim the throttle open adn once it started, it seemed like it was only running on 1 cylinder.
Over the winter, I started the troubleshooting and thought I had fixed verything up, but it won't start at all now and I have run out of ideas.
The work over the winter was:
-Checked for spark on each cylinder. Found one cylinder was getting weak or no spark (using a spark tester)
-Swapped wires from electronic switch box to coils. No spark cylinder followed the wire. i.e. switch box was dead
-Therefore, replaced switch box
-After replacing the box, check both cylinders with spark tester and they looked like they were getting good strong sparks
-Did a full carb cleaning and rebuild kit
-New spark plugs
-New fuel filter
-Kill switch on the tiller was getting very flakey. Replaced switch assy
-Also, as part of the annual maintance, replaced the therostat, lower end oil, impeller and did a general cleaning.
Tried starting the motor for the first time since all of this work today and it wouldn't go. A few symptoms - if I prime (overprime?) using the chock lever, the first few times I tried to start it, it almost seemed like a partial backfiring happened. Other than that, there was absolutely no indication that the motor wanted to start. I tired every combination of choke, no choke, throttle position, etc. Also, tried a few squirts of starter fluid into the card air intake in desparation - no luck.
So, now I am questioning everything, including my sanity. I'd love any ideas, theories, etc that you guys have.
Thanks in advance!
  #2
Old May 24th, 2008, 03:56 PM
Default Re: Help!! - 15hp Mariner starting problems
A follow-up question/theory - I don't think this is the case based on the lengths of the wires from the switch box to the coils, but stranger things are possible.
If I had accidently swapped the wires to the coils, so the switch box is telling the wrong coil to fire, would you expect the above symptoms? Also, can you come up with an easy way to determine if this is what I did?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mariner 15hp problems please help jono_uk Mercury & Mariner Outboards 7 April 6th, 2008 06:38 PM
1994 Mariner 90hp Starting Problems- need help! LonnieJ Mercury & Mariner Outboards 0 July 26th, 2006 12:47 AM
starting problems with mariner 90 snookered171 Mercury & Mariner Outboards 7 November 25th, 2005 12:04 PM
MARINER 60 STARTING PROBLEMS dadowales Mercury & Mariner Outboards 2 June 10th, 2005 11:38 AM
Mariner 45hp starting problems rick wilke Mercury & Mariner Outboards 3 July 19th, 2002 01:59 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
