Re: Rectifier Help
I have the same engine, and went through the same problems.
Check resistance on the input to your amp, trigger input should be 8.5 ohms
some trouble shoting matrix's say thay are good betwen 8 and 12 ohms
there wil be two input wires on the top of the amp and two on the bottom.
If you have a DVA meter or DVA attachment for your DVM meter you should be getting 150VAC while cranking the engine on your trigger inputs
Output to your coils should be 150 to 200VAC
the rectifier can cause the engine not to get spark if it goes bad, nothing to do with the circuit but the trouble shooting matrix says to remove the rectifier when trouble shooting the ignition.
also the engine needs to turn at 300 rom to produce good voltages, remove the spark plugs this allows the engine to spin faster with no back pressure from cylinders for ignition troubleshooting.
try unplugging the RED connector at the engine, this will eliminate the remote control ignition switch also, sometimes the switch goes bad and causes this problem, you will need to jump the ignition at the starter terminal with a set of battery cables if you remove the red connector
*NOTE* the engine can start and run if you remove the red connector so be prepared to choke it to shut it off
