krisnowicki
- Jul 11, 2007
- 1,172
I just replaced my impeller and all day the temp was between 140-160 ( I have thru hulls). However, I have two oil pressure gauges one on the dash and a back up on the engine. The one on the dash read about 20-25lbs all day the one on the engine read about 20 at idle and around 35 under way. Is 35lbs normal and good? If the on dash is right would the 25maybe 27lbs be ok? And finally if it was low wouldn't the engine be running hot?
