dave524
- Aug 27, 2005
- 116
Hello to all. I think I have some kind of problem with my boat. I used to run a all-terrain 40 from minnkota and had no problems at all. I recently purchased a Power Drive V2 with co-pilot and was using it the other day. All was well untill I made a long run of about 15 min in high speed and the 30 amp inline fuse blew. I went to my back-up which is only a 10 amp, and that blew immediatly. With the old motor i never blew either fuse. Do the newer motors pull more amps ? I am running about 15 feet of wire from the batteries to the motor. What guage wire should I be using, and what amp fuses, if any shoud I have iniline ? I took the motor apart to look for water intruson, and found none. The brushes are fine and seals are great. Confused. I must say that although it requires some getting used to, the co-pilot system seems to be a nice feature. Any ideas, as i am ready to rewire the boat for the new motor if i have to. Thanks in advance for your time. Dave
