  #1
Old May 22nd, 2008, 11:12 AM
ezmobee's Avatar
ezmobee ezmobee is offline
Send a message via MSN to ezmobee
Default Aluminum boat transom replacement progress and questions
I'm knee deep in replacing the transom on my '66 Starcraft. I have the motor off and everything else that was mounted to the transom. Lots of bolt cutting.
Here's the motor hanging in my garage and my chaotic workspace
Here's my transom with everything removed.
Here's the token picture of rotted wood pulp we all love to see
Here's my question. My boat has these 2 huge bolts through the transom. One on each side. They basically cannot be removed. They are like 8 inches long and welded to some sort of bracket inside the boat. You can see the bracket rivets on the ouside in the last picture. I have not seen bolts like this on other aluminum boats. Do you think I'm ok to just cut them off? Otherwise I'll need to fit the new wood in around them. I'm wondering if they were just there to aid in the assembly of the boat when it was being built. Thoughts?
__________________
1976 18' Starcraft SuperSport 90HP Evinrude
Restoration thread http://forums.iboats.com/showthread.php?t=357767
1966 16' Starcraft Jupiter 85HP Johnson
Restoration thread http://forums.iboats.com/showthread.php?t=338633 sold
  #2
Old May 24th, 2008, 11:15 AM
ezmobee's Avatar
Default Re: Aluminum boat transom replacement progress and questions
Bump
__________________
  #3
Old May 24th, 2008, 11:34 AM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
Leave the bolts and just work around them. They are pretty far near the corners. Were there nuts on them or ski loops? I would look to see if you could use a hardwood block and tap them through into the boat. What's on the other side?
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #4
Old May 24th, 2008, 11:41 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
i agree cut them or knock them out. looks like the old style tow ring mount, that had a threaded rod, and the nut on the inside, and the ring threaded on. rather than made in one piece.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old May 24th, 2008, 09:01 PM
joeyplumley's Avatar
joeyplumley joeyplumley is offline
I have the same transom and hull, and just replaced my transom. I have a line of 4 bolts/nuts on each side vertically, in that same area. None are welded in, just nuts and bolts.
I second the cutting/grinding to get them out, and replace w/ stainless.
__________________
The fleet:
-1979 18'6" Starcraft Super Sport, 1985 Mercury 60hp http://forums.iboats.com/showthread.php?t=260400
-1994 Kawasaki Super Sport X1 (750cc)
-1998 Arctic Cat Tigershark 640L
-Sevylor Voyager 9'2", Tanaka 1.75hp
  #6
Old May 24th, 2008, 11:19 PM
ezmobee's Avatar
Thanks guys. I'm going to cut them out. TD, that's probably what they are because my current tow loops are top-mounted but don't look original. Bob, there were nuts on them but the bolts are welded to some sort of bracket which is riveted to the hull.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Help with aluminum boat, transom replacement acke61 Boat Restoration and Building 3 April 26th, 2008 12:25 AM
Aluminum boat transom replacement ezmobee Boat Restoration and Building 9 April 17th, 2008 07:38 AM
Aluminum boat transom replacement San Antonio Cop Boat Restoration and Building 2 December 8th, 2005 05:53 AM
Aluminum Boat Floor Replacement turtle1173 Boat Restoration and Building 16 November 20th, 2005 07:55 AM
Aluminum Boat Questions tlamm Boat Topics and Questions (not engine topics) 1 August 14th, 2002 05:45 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
