  #1
Old May 22nd, 2008, 03:33 AM
Doug Redinger Doug Redinger is offline
Default Old Mercury(1963) inline six carb question??
I have a 1963 Mercury 850 inline six ( 90 cu. in. ) which I have modified to make it like a Merc 1000. I installed the exhaust baffle out of an old Merc 1000 and upgraded the carbs to the KC1A carbs also from an old Merc 1000. My question is this. Are the factory carburetor jetting tables set on the rich side? I have heard in the past that some manufactures set the carb rich to avoid a lean condition and possible engine meltdown. Most of my boating is at 5000 ft. in elevation or higher and I am trying to get the carb jetting dialed in. I currently am running (.069) jets which the factory spec book lists for sea level to 4000 ft. The factory spec book lists (.067) jets for 4000-7000 ft. Which would be about right for my elevation. I don't have the (.067) jets but I do have a set of (.064) jets. I figure if the tables are set overly rich anyway, how risky would it be to run the (.064) jets? You old Merc Guru's have any thoughts on this?
  #2
Old May 22nd, 2008, 10:22 AM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
Default Re: Old Mercury(1963) inline six carb question??
Hi Doug,
How do your plugs look now after a hard run? If they're running really black, you could definitely go a bit leaner. Are the .064s the ones out of your original 850 carbs? If the plugs are running a chocolate brown now, then going that much leaner would probably be too much. If the motor were mine and the plugs were running real dark, I might try it for a quick run witha clean set of plugs and then read the plugs again. Try it at your own risk...
- Scott
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
  #3
Old May 22nd, 2008, 10:47 AM
emckelvy emckelvy is offline
Use the hi-altitude jets meant for a 100 HP. You're moving a lot more air thru the motor with the 100HP carbs than with the old 85HP items.
Wouldn't be a bad idea as suggested to read the plugs just for G.P., after rejetting.
Keep in mind that regardless of jetting you'll produce less power at higher elevations due to the reduced air density. But rejetting will at least allow it to run cleanly.
If you find you're not getting up to the rated rpm at the higher elevations, you'll probably need to change to a prop 2" less in pitch.
HTH.............ed
  #4
Old May 22nd, 2008, 04:01 PM
I appreciate your responses. I will try a high speed run with the (.064) jets and a clean set of new plugs. She runs really good now, but I am always looking for ways to make it run even better. 5200 RPM on a 80 degree day at 5200 ft. of elevation with a brass 2-bladed prop 13 3/4" X 19 pitch with a light load. Will turn 5500 RPM and 40 MPH in the early morning when the air is in the 30's. The (.064) jets will flow about 86% of what the (.069) jets will flow, and air density decreases about 3-3.5% per thousand feet above sea level, so at 5000 ft. I figured the (.064) jets would be just about right. 82.5 -85% of sea-level air density.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Carb Question on 115 Merc Inline 6 fishaholic911 Mercury & Mariner Outboards 12 September 12th, 2006 02:13 AM
Where is the thermostat in an old mercury 1150 (115hp inline 6 1976) ? isoaga Mercury & Mariner Outboards 4 April 3rd, 2005 12:20 AM
inline carb question phatmanmike Mercury & Mariner Outboards 4 September 14th, 2004 04:02 PM
1963 Inline 6 Lead Additive or no bh357 Mercury & Mariner Outboards 2 March 2nd, 2004 06:10 AM
Info on old Kiekhaefer / Mercury inline 6 outboard marinegundoctor Mercury & Mariner Outboards 8 August 12th, 2001 11:49 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
