  #1
Old May 21st, 2008, 11:30 PM
Glastron T Glastron T is offline
Default
I'm having problems with the idle on my 120 Hp Evinrude. It's got a "miss". I thought the missing was due to a fuel/air leak so I rebuilt all 4 caburetors. After rebuilding the carbs it still has the same miss. Out of the water, every time the motor spudders a larger than normal puff of smoke comes out of the prop's exhaust port. I'm not sure if it's a fuel issue or something else now??? I was wondering if the caburetor's floats are out of adjustment, if I have an air or fuel leak somewhere or if it's an electrical problem... It's warming up and it's getting to be skiing weather!! Any help anyone can give me is greatly appreciated!! Thanks!! Tommy
I've got a 120 Hp Evinrude 1986 model with a miss, at least I thinks it's a miss... The motor runs decent for about 30 seconds after cranking then goes to puffing. It's not a back-fire, but running it out of the water every few seconds it sounds like it miss fires and a larger puff of skoke exits the props exhaust port. I replaced the carb kits thinking it might have an air/fuel leak and it didn't change a bit. FYI: A while back I replaced the oil injection fuel pump with a basic vacuum pump, I was scared the pump might go out and leave me paddling. Any help would be greatly appreciated!!
  #2
Old May 22nd, 2008, 03:47 PM
Captain Jeff Captain Jeff is offline
Default Re: Setting floats on a 120 Evinrude (1986)
Could be the fuel mixture is too rich to consistently ignite. Could be other things, timing issue, etc. Search the forum for link and sync. I believe the floats should be parallel to the bowl when the needle valve is closed.
  #3
Old May 22nd, 2008, 04:08 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Welcome to iboats. did you do all this, http://forums.iboats.com/showthread.php?t=244013?
have you checked your compression and spark, spark should jump atleast 1/2 inch, compression over 100psi, and with in 10% of each other.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old May 22nd, 2008, 04:39 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Most likely sucking air somewhere. the first thing is to determine which cylinder / carb body. Take the airbox cover off and start it up. Place a toothpick in the idle jets one at a time until you figure out which one it is. The idle jet is the lower one of the two air bleeds.
  #5
Old May 22nd, 2008, 07:31 PM
please do not double post the same problem.
__________________
FLORIDA GATORS
TEBOW Country
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Help setting Carb Floats! mwinchel Mercury & Mariner Outboards 8 March 26th, 2008 12:20 PM
setting floats? icedogs66 Mercury & Mariner Outboards 3 July 21st, 2007 10:22 AM
setting floats icedogs66 Mercury & Mariner Outboards 2 July 16th, 2007 06:40 PM
Setting floats on 1975 Merc200 (20HP) Soxfan Mercury & Mariner Outboards 1 September 17th, 2003 08:14 PM
Setting carb floats on an 86 85hp force GETDANET Force & Chrysler Outboards 1 March 16th, 2002 11:33 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
