Go Back   iboats Boating Forums > Repair and Maintenance > Johnson & Evinrude Outboards
View Poll Results: evinrude stalling
evinrude stall 0 0%
evinrude 175 0 0%
evinrude 1993 0 0%
evinrude starting 0 0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Johnson
Parts
Johnson
Repair Manuals
Powerheads and
Lower Units
Boat
Propellers
Evinrude
Parts
Evinrude
Repair Manuals
Reply
Thread Tools Search this Thread Display Modes
  #1
Old May 19th, 2008, 04:25 PM
smarvelle smarvelle is offline
Default evinrude 1993 spitfire stalling at low speed
My 1993 Evinrude spitfire series starts ok and runs great at high rpms. When I am idling around (very slow speeds) it starts to cough and sneeze if I dont give it more throttle it will stall. Another senerio is if the engine is good and hot I will shut it off and do a little fishing. In about 20 to 30 minutes hen I restart it . If I dont throttle up in newtral int will stall. Ive replaced the power pack, optical eye , spark plugs, and had my carbs cleaned please help me. Thanks
  #2
Old May 19th, 2008, 04:37 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: evinrude 1993 spitfire stalling at low speed
sure sounds, like running lean, fuel starvation. http://forums.iboats.com/showthread.php?t=244013
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old July 1st, 2008, 12:43 PM
Someone else also told me I could be running lean I had a sync and link done and the carbs cleaned it has helped a little but I'm still experiencing the same issue. can the vro be bad or need adjusting? This problem has been going on for a year and has been driving me crazy. Any information would be greatly appresiated. Thanks
  #4
Old July 1st, 2008, 01:13 PM
try setting your idles speed stop screw up a little. what rpm is it idling in gear.
__________________
FLORIDA GATORS
TEBOW Country
  #5
Old July 1st, 2008, 01:25 PM
Bdt 1967's Avatar
Bdt 1967 Bdt 1967 is offline
How do you do the link and sync? Sounds like my problem.
  #6
Old July 1st, 2008, 02:50 PM
it idles around 700 in newtral. I'm not sure how far it drops when I put it in to gear. I had an evinrude dealer perform the sync and link thanks for the quick responce.
  #7
Old July 1st, 2008, 02:55 PM
How do I adjust the idle screw?
  #8
Old July 1st, 2008, 03:01 PM
this is a different motor. but should be similar. the very top bolt in the picture is the idle speed stop screw, should have lock nut on it, and rubber tip, loosen lock nut, and turn clockwise to speed up idle. the idle in gear and in the water should be around 650-to 750. as slow as you can get it to run, without stalling, when shifting. then retighted the lock nut.
__________________
FLORIDA GATORS
TEBOW Country
  #9
Old July 1st, 2008, 04:18 PM
If the motor is running lean would this damage the motor in the long run?
  #10
Old July 1st, 2008, 11:13 PM
wilde1j wilde1j is offline
Yes, for sure. A shop manual would give info on how to find/correct lean conditions. Stuff like air leak into crankcase, exhaust leak inside cowl, etc. Exhaust leak can be checked by removing cowl and running ... does the sneezing go away? If yes, exhaust leak. Lot of other stuff to check.
__________________
Jim
  #11
Old July 8th, 2008, 03:06 PM
You were absolutly correct Jim. I brought my boat to the local Evinrude dealer he located an exhaust leak from a hose around the starter area. The boat finally runs nice!! This idle issue has been going on for over a year. Thanks for all the help. Sean
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
low speed stalling beachblaster Mercury & Mariner Outboards 5 October 5th, 2006 01:04 PM
Low speed stalling Boston Habba Mercury & Mariner Outboards 4 July 19th, 2004 06:36 PM
1995 Merc OB stalling at low speed telemorgan Mercury & Mariner Outboards 4 May 3rd, 2004 03:05 AM
175 HP Evinrude intruder 1993 spitfire series BigR Johnson & Evinrude Outboards 3 July 29th, 2003 02:35 PM
1993 175 Evinrude 60 Degree Spitfire Dusky203 Johnson & Evinrude Outboards 22 September 8th, 2001 05:11 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
