I am in need of replacing my bunks. I had thought about using those plastic type 2 x 4s but after launching my new (new to me anyway) boat recently, I realized it launches very easily. Anyway, my bunks are 2 x 4 carpeted. The brackets that hold them in place are c shaped and cradle the bunk. The bottom of the bracket looks to have some type of serrated edge that bites into the bunk. On each side, there are holds for a screw/nail. The bunks now are carpeted OVER the bracket so the 2 x 4s must have been installed first and then carpeted over. I'd like to get 2 new bunks set up and ready to go and then re-install the bunks and screw small lag bolts in from each side to secure the bunk.
My question is (and it may not matter) ...is there a preferred way? I can't see that it matters myself but thought I'd ask.
Also, the side guides have the carriage bolt going through the carpet so it is exposed. In the past, I have always done those with the carriage bolt on the INSIDE of the carpet so the metal doesn't touch the boat. Again, it probably doesn't matter in the case with an aluminum boat but is there a preferred way?
Thank you.
Thank you.
