Tilt/trim Problems
STUBBY22
I RECENTLY PURCHASED A PONTOON BOAT WITH A 60 HP ELPTO MERCURY ON IT. THE TILT/TRIM WORKED FINE AT FIRST, BUT NOW THE MOTOR RUNS WITH NO RESPONSE FROM THE RAM. FLUIDS HAVE BEEN CHANGED AND THE MOTOR WILL LIFT WITH APPLIED PRESSURE. iS THERE A REBUILD KIT OR REPAIR FOR THIS PROBLEM----1994 YEAR MODEL
j_martin
Re: Tilt/trim Problems
It's possible the manual lift release (screw) is loose.
Look it up in your owner's manual and go check it out.
hope it helps
John
