Re: Mercury 900 78' stator?
tredding, You should be able to peek under the flywheel and see the stator. If not, you might like to remove the 8 5/16" fine thread bolts that are clustered arounf the flywheel nut. You should be able to see, remove and install the stator after eh outer flywheel is removed.
