  #1
Old May 17th, 2008, 06:42 PM
donttakemydogs donttakemydogs is offline
Default 6HP Evinrude cuts out at high RPM's
I just purchased a small aluminum boat with a 6HP Evinrude. This thing had set for almost 5 years without being touched. When I got it home I flushed the fuel system, put in fresh fuel and it actually started on the 4th pull. I couldn't believe it.
Of course it needed some TLC. It wouldn't idle, spit and sputtered etc. etc. I rebuilt the carb, replaced all the hoses, bought a brand new fuel tank and it started on the first crank and purred like a kitten. When I got it out on the water, it would only run with the choke on. At high RPMS, I had to "feather" the choke to keep it going.
Yesterday, I rebuilt the fuel pump. It made a huge improvement, but it still cuts out when you open up the throttle.
Does anyone have any suggestions? I feel like I did the work on the carb and fuel pump correctly since it did make a big improvement.
Thanks for your help.
  #2
Old May 17th, 2008, 07:02 PM
Vic.S's Avatar
Vic.S Vic.S is offline
Default Re: 6HP Evinrude cuts out at high RPM's
It could just be pulling air into the fuel system somewhere between tank and pump. If pumping the bulb keeps it going that's the cause or still pumping poorly but more likely you still have not got the carb properly clean. Running ok with a bit of choke points to that.
no air leak between carb and engine?
if it cuts out completely then look for ignition problems but not if it'll run with some choke
  #3
Old May 17th, 2008, 10:06 PM
I've checked all the fuel lines and there is no way they could be sucking any air. It has to be in the carb or pump. Maybe i didn't clean it good enough.
One thing hit me while I was scrathing my head trying to figure it out. The fuel pump kit that i bought did not have the little plastic seats for the valves in the pump housing. i guess i'll try to find those and see what happens. that's the only part that has not been replaced in the fuel system.
  #4
Old May 17th, 2008, 11:25 PM
Solittle Solittle is offline
Ah - Did you replace the water pump? It may not be reaching high rpms due to overheating especially if it sat for 5 yrs.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
15 hp evinrude cuts out at high speed sterling3663 Johnson & Evinrude Outboards 2 June 11th, 2006 08:45 AM
2000 salt water 225 cuts out at high RPM's pontoon chief Yamaha & Suzuki Outboards 3 October 1st, 2004 06:48 AM
1978 evinrude 55HP cuts in and out at high speeds only aejeffor Johnson & Evinrude Outboards 7 May 3rd, 2004 01:46 PM
'95 triple 1100 Yamaha jetski (cuts off when rpm's get to high) squeak1712 Yamaha & Suzuki Outboards 3 June 11th, 2002 02:46 PM
9.9 evinrude cuts out at high throttle jeffm-blackCat Johnson & Evinrude Outboards 3 May 5th, 2002 06:00 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
