  #1
Old May 17th, 2008, 05:49 PM
huskeraaron huskeraaron is offline
Default 1976 Evinrude 55hp always in drive.
I just purchased a small boat with a 55hp Evinrude. It had not been used for several years before I got it. It runs really well but it seems to be stuck in drive. No neutral and no reverse. Any help would be greatly appreciated.
  #2
Old May 17th, 2008, 06:14 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1976 Evinrude 55hp always in drive.
disconnect cable at the motor and try shifting at the motor.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old May 17th, 2008, 06:17 PM
5150abf's Avatar
5150abf 5150abf is online now
Ya , sounds like the shift cable broke.
Have someone move the throttle and see what moves at the engine.
If only the carb linkage moves it is a cable.
__________________
GO IRISH!!!!
  #4
Old May 17th, 2008, 06:44 PM
Thanks for your help guys.
Its nice to see some college football fans on here.
  #5
Old May 17th, 2008, 07:01 PM
It does not look like there is a shift linkage. Could this be an electronic shift motor?
  #6
Old May 17th, 2008, 11:08 PM
Deanrt's Avatar
Deanrt Deanrt is offline
Sorry husykeraaron, Eventhough my mom was born in Nebraska, The Oregon Ducks are the team brutha. Do we have the history of the Huskers, of course not. In fact, growing up I was a Sooner's and Husker fan. OOOOOh I bet you didnt like that? Sooners????????????????????. Just messin with with ya bro, good luck on your motor.
  #7
Old May 18th, 2008, 05:04 AM
what is you model number, if it is a 1976 it would not be electric shift. but if another year, yes.
__________________
FLORIDA GATORS
TEBOW Country
  #8
Old May 18th, 2008, 12:07 PM
Were would I find the model #? I guess the boat is a 76 and I thought the motor was the original. Thanks
  #9
Old May 19th, 2008, 11:39 AM
  #10
Old May 19th, 2008, 12:18 PM
look for a 1"x2" plate on the transom bracket, could be under the front of the motor or either side outside, also look on the engine block for a plug like this.
__________________
FLORIDA GATORS
TEBOW Country
  #11
Old May 26th, 2008, 06:17 PM
Finally got time to get back to the boat. Model # is 55873S and the serial # is J01227. Thanks for any help.
  #12
Old May 26th, 2008, 08:15 PM
terrykitts terrykitts is offline
Hi i have a 1971 100 hp with no reverse. I was wondering if you got your problem fixed if so what was it. mine goes foward in reverse or nothing at all thanks....
  #13
Old May 26th, 2008, 08:18 PM
Mine actually starts in gear. Its all go all the time. I have not yet got this resolved.
  #14
Old May 26th, 2008, 09:32 PM
rolmops's Avatar
rolmops rolmops is offline
That is an evinrude Triumph. It is a 1968 three cylinder with some sort or electric shift,either hydramatic or electramatic,I think hydramatic.
When those shifters fail they revert to forward only so you cannot get stuck on the water.
Other people with a lot of know how about these shifters will shortly help out by telling you exactly how to check the electronics involved.It can be as simple as a loose wire or the wrong lower unit oil,but it can also be a big pain in the neck.
__________________
Make sure the plug is in
  #15
Old May 26th, 2008, 09:42 PM
CATransplant's Avatar
CATransplant CATransplant is offline
Quote:
Well, that's actually a 1968 55hp you have there. It's an electro-hydraulic shift motor. It defaults to forward so you'll always be able to get back to the dock in case something fails.
If it isn't shifting when it's running, then you need to track down the problem. Often, it's in the controls on the boat. If not there, it's in the gearcase. Parts are available, but expensive, so let's hope it's in the controls.
Go Big Red!
  #16
Old May 26th, 2008, 10:24 PM
Thanks for your help. This is my first boat so things are new to me. I do know a little about electronics, I did trace the wires from the controls to the motor. I pulled the connector apart at the motor where they drop down to the lower unit. I used my ohm meter and had my son move the controls. With the key off my ohm meter showed some change. I turned key on and switched to the volt meter, now I saw no changes. Could this be a power problem? Or is this something worse. Since I just got the boat and it had been sitting for several years I replaced the lower unit grease. What came out was like white bearing packing type grease. What I put in was more of a rearend type liqued grease. Thanks again.
  #17
Old May 26th, 2008, 11:00 PM
rolmops's Avatar
There are 2 types of lower unit oil.You need the type for electric shifting.It usually is the A-type.Go to a marina to make sure that you get the right kind.
White goop in your lower unit means water penetration.Check all your seals and replace the plastic washers that are under the oil changing screws in the lower unit.
__________________
  #18
Old May 27th, 2008, 11:46 AM
So from reading some other posts it looks like I should have some voltage on the wires going to the lower unit. Is this correct. With the key on I get no voltage.
  #19
Old May 27th, 2008, 07:50 PM
  #20
Old May 27th, 2008, 08:43 PM
rolmops's Avatar
Smile Re: 1976 Evinrude 55hp always in drive.
There is really not a lot we can tell you at this point.
We dated the engine,so now it is up to you to buy a manual(preferably an original manufacturers).With that in hand you can check the lower unit and the electric shift.
Once you have some testing results,it will be possible to help you farther along the way because then you can provide us with more info about the problems that you have with the shifter.
You can find the factory manuals right on this website.Just take the 1968 55 hp Johnson manual.Johnson and Evinrude motors are exactly the same
__________________
  #21
Old May 27th, 2008, 09:55 PM
You guys have been great thanks for all your help.
  #22
Old May 28th, 2008, 07:38 AM
aaromba aaromba is offline
Just did this with my 1968 55 HP johnson. The oil in the case needs to be type C, it will say on the oil bottle for electric shift. If you do a search on 1968 johnson shifting problems you will find a lot of help. It will have you check voltage on the wires in nuetral, reverse and forward (sorry cant remember) it will have voltage on one wire in one gear voltage on two in another and none on either in the other gear. There is a switch in the shift lever up front. you have to take it off, do this only if you trace it to there its kinda of a pain to put back together with one person. My problem was the solenoids and the valve in the lower end, $350.00 thru sea-way in Oregon. Changing the oil is probably all it is!! Good luck!!
  #23
Old May 29th, 2008, 01:30 AM
Thank you so much aaromba. I believe I have found the trouble. For sure I have the wrong gear lube (I just used what had come with the boat). I also think the vacuum starter switch is bad. I will let you know this weekend. Thanks again
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1976 55HP Evinrude billybones Non-Repair Outboard Discussions 3 March 16th, 2008 01:40 PM
1976 55hp Evinrude develops miss when warm jason7253 Johnson & Evinrude Outboards 1 December 30th, 2006 07:40 AM
Differences between 1976 55hp Evinrude and Johnson dramadoc Johnson & Evinrude Outboards 2 October 3rd, 2003 02:07 PM
1976 Evinrude 55hp #cyl? garden hose? dramadoc Johnson & Evinrude Outboards 3 September 14th, 2003 08:54 AM
1976 55hp Evinrude, timer base? Clay P. Johnson & Evinrude Outboards 0 August 6th, 2002 04:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
