Happy sailor
- Apr 14, 2008
- 2
I have a 5HP 4-stroke Tohatsu about six years old. I use it on a 22 ft sailboat and in general it has not had much use. It starts easily, at moderate to high throttle positions it runs well. At low throttle positions, say near idle, as when I'm coming in to the slip the engine stalls. If I think it's about to stall I squeeze the syphon bulb and the engine picks up and keeps running. So as I approach the dock I have to keep my hand on the gear shift, the tiller and the siphon! I've inspected the tank filter, the hose, and the siphon bulb. Can't see any obvious cracks in the rubber or dirt in the filter. Should the rubber be replaced anyway? Or might there be another problem, say the fuel pump?
