Re: 50 hp tilt and trim
WOW!
That is salty, I think I paid $480 with the trim gage, I have the PT130 because I run a 50 horse.
As TD said it would be a real pain to get an OEM unit in, you would have to take the engine off and take the mount apart and that is if you can find one that even works.
I have looked at CMC's on Ebay too and it seems to be one of the few things you can't catch a deal on.
Try your luck on an OEM unit, you might luck out or you may find it is just as much.
If you want TT those are really your only options so you have to pick one or skip it.
Hope you find something, good luck
