  #1
Old May 15th, 2008, 04:19 PM
woodowl woodowl is offline
Default '83 Evinrude 15hp 2-stroke smoking and dying
I just got a used 15hp '83 Evinrude and have been trying to get it usable. I know a little about engines, but I'm no mechanic, although I do have a manual for the motor type.
I have replaced the spark plugs and fuel pump, replaced the gear oil, and taken off and cleaned the carborator with (spray can) carborator cleaner. It starts, but smokes a LOT, and dies after about a minute, no matter what speed it's running at.
Many thanks,
Damien Kurrin
  #2
Old May 15th, 2008, 04:27 PM
Gary H NC's Avatar
Gary H NC Gary H NC is offline
Default Re: '83 Evinrude 15hp 2-stroke smoking and dying
Welcome to Iboats!
When it starts to die try squeezing the fuel primer bulb.
You may have a fuel line sucking air or carb problems.
Did you remove the core plugs inside the carb and clean all the orifices?
Usually just spraying carb cleaner through them does very little.
Pump the primer ball up and look for any leaks.
__________________
1981 ChrisCraft 210 Scorpion K,175 Johnson SeaHorse
  #3
Old May 15th, 2008, 06:18 PM
mikesea mikesea is offline
The only way to clean a carb is removal and total disassembly,It is probably smoking alot because it was "pickled with oil"before laying uphowever 2 cycle engines do smoke because oil is mixed with gas
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1990 Johnson 15hp rough starting and dying samo_ott Johnson & Evinrude Outboards 13 July 13th, 2007 03:11 AM
1999 Evinrude 4-Stroke 15HP mtemple Johnson & Evinrude Outboards 3 May 22nd, 2007 11:08 PM
15hp 1989 dying after idle pierretheron Johnson & Evinrude Outboards 6 December 6th, 2006 01:29 AM
weight difference between a 2-stroke 15hp and a 4-stroke 15hp? b.gagnon Non-Repair Outboard Discussions 8 April 12th, 2005 07:28 AM
Jhonson 15HP smoking hardtouse Johnson & Evinrude Outboards 2 July 14th, 2004 11:19 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
