  #1
Old May 15th, 2008, 02:21 PM
hornofplenty hornofplenty is offline
Default possible carb problem 83 mercury 50hp
Hello everyone,
I seems that when I pump the primer bulb that it gets to a point where fuel comes out of the lower carb if I keep pumping the bulb...is this normal or is a carb rebuild in my future?
The motor runs though but doesn't start easy, but that could just be because of the starter not staying engaged.
  #2
Old May 15th, 2008, 02:36 PM
fishdog4449's Avatar
fishdog4449 fishdog4449 is offline
Default Re: possible carb problem 83 mercury 50hp
Somethiing is wrong with the needle, seat, or float. What happens is, when you pump the bulb the fuel is forced into the float chamber. The float rises with the gas level until it forces the needle to close and stop the gas flow since the chamber is full. If the needle gets damaged or seat is damaged or float is saturated with fuel, it will not shut the fuel out effectively. The excess fuel will flow out of the carb like you are saying. It is not a hard repair, very inexpensive, but you do need a manual to adjust the float properly.
__________________
1972 Macgregor 25'
1981 Glassmaster 17 '76 Mercury 1150 tower of power
  #3
Old May 15th, 2008, 03:44 PM
Thanks fishdog, I'll get a manual.
  #4
Old May 27th, 2009, 04:25 PM
geraldine geraldine is offline
I am having a very similar problem, I own a 1979 merury 50hp and when i pump the bulb gas comes out of the top and bottom carb. It used to crank and run good but then would die on me and then not start. While on the water I could bang on the carb and get it started, but then would try to die and I would have to keep beating on it to keep running. Now it will not start at all. Any ideas?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
83 mercury 50hp, starter won't stay engaged hornofplenty Mercury & Mariner Outboards 7 May 15th, 2008 03:39 PM
83 brown band 50hp Mercury ebtenn Mercury & Mariner Outboards 0 September 9th, 2007 01:53 PM
Mercury 50HP Carb. slangley Mercury & Mariner Outboards 1 August 8th, 2003 05:44 AM
1972 50hp evinrude carb adjustment problem NJ-BILL Johnson & Evinrude Outboards 1 May 12th, 2002 08:46 PM
50hp mercury----carb or throttle?? tex Mercury & Mariner Outboards 1 June 13th, 2001 01:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
