  #1
Old May 14th, 2008, 12:06 PM
hornofplenty hornofplenty is offline
Default 83 mercury 50hp, starter won't stay engaged
Hello everyone,
I'm having trouble with my starter not staying engaged even though i hold the key in the start position. This is making it hard for me to start the motor since it doesn't stay engaged long enough for the motor to catch. The gear with pop up and engage the flywheel crank for a second than fall back down. Is this normal? I thought that if you keep the key in the start position than the starter would stay engage until you release the key. Any help would be appreciated...i'm a first time boat owner with no knowledge of outboards.
  #2
Old May 14th, 2008, 12:13 PM
bhile's Avatar
bhile bhile is offline
Default Re: 83 mercury 50hp, starter won't stay engaged
Have your battery load tested and make sure all your battery cable connections (both ends) are clen and tight.
__________________
Fair Winds and Following Seas
Bill
PTC USN ret
  #3
Old May 14th, 2008, 12:38 PM
thanks for the reply, i'll try that tonight and let you know what happens.
  #4
Old May 14th, 2008, 03:43 PM
Silvertip Silvertip is offline
The starter (the bendix) will remain engaged only if the starter is spinning fast enough to hold it up. Once the engine fires the engine drives the bendix faster than the starter so it sort of spits it out of engagement. The key here is that the battery needs to be fully charged and you need good cables and connections. Don't just look at them. Disconnect them at both ends, make them shiny clean and reinstall them securely.
  #5
Old May 14th, 2008, 07:30 PM
Yepblaze's Avatar
Yepblaze Yepblaze is offline
Battery
Make sure you are using a good freshly charged starting type battery.
I've seen where deep cycle batteries cause issues like this.
  #6
Old May 15th, 2008, 02:07 PM
well, I'm back...I cleaned all the connections and freshly charged the battery and still it doesn't stay engaged long enough for the engine to start. Could the problem be internally with the starter? It seems like it is spinning at a good rate but obviousely not as fast as the motor went it tries to start. I do however get the motor to start eventually...should I just live with it or try something else?
  #7
Old May 15th, 2008, 03:15 PM
CharlieB CharlieB is offline
As Silvertip pointed out, as a cylinder fires the crank accelerates, disengaging the starter drive.
If your tune up is old, poor fuel, anything else that contributes to a hard starting engine, one cyl may not be enough to start your engine.
Are your spark plugs fouled, is your fuel fresh?
  #8
Old May 15th, 2008, 03:39 PM
brand new plugs and fresh fuel, although the engine hadn't been ran for about 6 years...could the carbs be gummed up?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Starter stay engaged... saumon Mercury & Mariner Outboards 4 November 9th, 2005 12:12 PM
starter won't stay engaged rthalls Johnson & Evinrude Outboards 31 August 11th, 2004 07:24 PM
Bendix won't stay engaged long enough to start motor. foreman33 Johnson & Evinrude Outboards 27 August 8th, 2004 06:24 AM
1991 evinrude 25 HP electric start -starter won't stay engaged rthalls Johnson & Evinrude Outboards 8 April 5th, 2004 05:42 PM
Starter overheating - '83 50hp Johnson jbravo Johnson & Evinrude Outboards 3 October 28th, 2003 08:55 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
