Re: Mariner 115 Water Pump?
Telltale outlets on outboards sometimes clog up. They therefore are just an indicator. Merc waterpumps usually last 3-4 years unless you run thru a bunch of sand or muck, and then who knows when they will fail.
Can you put your hand on the block and see if it is hot? Inline sixes usually run lukewarm at most, at idle. They get hotter under load and at high RPM
You should change the impeller if it is more than two years old. It is not a hard job, but will require you to get a manual.
