  #1
Old May 13th, 2008, 09:08 AM
jeremy5780 jeremy5780 is offline
Default 90 hp evinrude trouble starting
i have 1986 90 evinrude vro minus the vro pump i removed it. I did a decarbon on my motor a few weeks ago with some seafoam. And the past two time i took my boat out it takes me forever to get it started. when i first put in it acts like it is flooded i have to open the throttle wide open then choke it and start and it take probably 9 to 10 tries before it starts up. once warmed up it idles fine it runs wide open like a champ if i shut it off then start it right back up it starts fine but if i let it sit for a minute or two i am right back to trying to get it started again. Could it be dirty carbs? or an air leak? I just dont know since it runs so good once started? Any ideas?
  #2
Old May 13th, 2008, 09:13 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 90 hp evinrude trouble starting
you have a primer solenoid, rather than a choke. have you tried starting without choking, sounds like it is flooding. also red lever should be i the run postion, in line with the body of the solenoid. like this:
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old May 13th, 2008, 09:34 AM
yes it is inline and yes i have started without choke before but only with the throttle wide open will it start and it takes quite a few tries
  #4
Old May 13th, 2008, 12:35 PM
i had the same motor different year, start by pumping bulb, tilt all the way down, in neutral, idle lever all the way up, turn key to on push in on key, holding key in turn to start. if it does not start, release key and try again. once it starts you may have to bump key in a couple of times to get it to settle down, lower fast idle lever. you also have to have a fully charged battery these motors have to turn +-300 rpms in order to start.
__________________
FLORIDA GATORS
TEBOW Country
  #5
Old June 29th, 2008, 11:14 PM
JMOG_04 JMOG_04 is offline
Smile Re: 90 hp evinrude trouble starting
That info helps alot I have a 86 90hp evinrude that was doing the same thing
  #6
Old June 30th, 2008, 12:20 AM
clanton clanton is offline
Clean the nipples on the carbs, that the primer hose connects to.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
100 hp evinrude trouble starting schonltd Johnson & Evinrude Outboards 2 July 25th, 2008 11:36 PM
1988 johnson 90 HP Ignition/starting trouble bjmess21 Johnson & Evinrude Outboards 8 October 17th, 2006 08:12 PM
'66, 6 hp Evinrude trouble starting b22smith Johnson & Evinrude Outboards 3 January 23rd, 2004 01:05 PM
Starting trouble after motor is warm//1997 Evinrude 90 HP coolhand24740 Johnson & Evinrude Outboards 0 August 25th, 2002 03:58 PM
1968 Evinrude 85 HP having trouble starting firemedic19077 Johnson & Evinrude Outboards 4 March 16th, 2002 04:25 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
