  #1
Old June 19th, 2002, 05:15 AM
radartk radartk is offline
Default Mercury Throttle & Shifter Problems
Morning folks, I went fishing with my 40hp. Merc, bass tracker. everything was fine until I was coming into the bank, when suddenly the shifter was hard to move. Additionally, the motor would not go to full throttle, because of the shifter. Does anyone know of a place on the web, that shows the insides of the shifter/throttle? Or what could be causing this.Thanks,TK in Tenn.
  #2
Old June 19th, 2002, 06:16 AM
mellowyellow mellowyellow is offline
Default Re: Mercury Throttle & Shifter Problems
I would start with the cables first.had same problem and there was a kinkin the cable.... good luck!PS. you need to post what year motor
  #3
Old June 20th, 2002, 12:00 PM
Spidybot Spidybot is offline
The remote box (with the handle) is really pretty simple. It handles gear shift and throttle in a coordinated way to ensure you engage gear at the right (low) rpm.The connected rods and links in the motor are set up to ensure that gears are engaged before adding throttle etc.Before diasassembling the box:Look for kinks and cables needing adjustment. If no obvious solution try disconnecting the cables at the motor and move the levers by hand.Then turn to the box.
  #4
Old June 23rd, 2008, 02:45 AM
JoeBuck JoeBuck is offline
I have a 2008 Verado 150 equipped with Smartcraft gauges. I sometimes have issues with shifting forward or into reverse from neutral, once it stayed in forward when I put it in neutral. My alarm goes of and signals "shifter critical error". My repair shop said everything checked out fine. I just had it out yesterday.... and the same thing happened. I waited a few hours and tried it again.... and it worked fine. Any suggestions?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
50 hp mercury thunderbolt shifter problems troubledinottawa Boat Topics and Questions (not engine topics) 4 September 13th, 2008 01:07 PM
1989 9.9 mercury shifter problems ohmybad Mercury & Mariner Outboards 2 August 14th, 2006 03:16 PM
Mercury Throttle/Shifter Wires umfangler Mercury & Mariner Outboards 2 August 30th, 2005 05:36 AM
Mercury throttle problems vette-1 Mercury & Mariner Outboards 1 June 24th, 2005 06:41 AM
Mercury Quicksilver Shifter Problems Bryan Mercury & Mariner Outboards 5 July 10th, 2001 11:07 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
