hey hopefully someone can help.i bought a 1994 22 ft crest pontoon 94 90 hp force 1st time i took it out ran great throttle cable a lil toght. well i took it out the second time put in reverse fine neautral fine went to forward and it didnt want to go into gear until it started reaving a bit and was jumping in gear. so i took cabbleoff and adjusted to get it to go into gear and that made it go into gear right butthe idle wasnt right. so i took foot off and replaced all seals and cchecked gears and everything in foot. is ok cant get the cable adjusted right took shifter apart and the piece that the cable hooks to well it bolts on one side and cable slides on *** and *** goes into another hole it was out so i put it back still cant get it adjusted to go into forward reverse ok neutral ok??? please help
