sparkly paint??
mtduckhunter
where can i get sparkly paint like on bass boats? and how much does it cost?
Re: sparkly paint??
Ayuh,...... On Bass Boats,.... That ain't Paint.......
Even if you can Find what you're looking for,.... Installing it is a Very Involved process....
tashasdaddy
Re: sparkly paint??
you are speaking of metal flake. has really gone out, as it oxidized so badly.
tonyg11780
Re: sparkly paint??
Yea TD, usually you can buff out oxidation in gel coat, but once it gets to the point that the flakes are protruding its over with...time to spend alot of money...
Chris1956
Re: sparkly paint??
Metalflake paint is made up of three layers. The first is a base color which is sprayed onto the hull. The second layer is aluminum flakes in a clear binder that is sprayed over the base coat. Finally a clear coat is sprayed over the flakes.
mtduckhunter
Re: sparkly paint??
is this expensive? how much work is involved?
Chris1956
Re: sparkly paint??
When I discussed painting my speedboat with a metal flake finish the body shop guy did not want to do it, since the flakes get all over his shop, and make a mess. I would guess it will cost two-three times what a regular paint job goes for.
mtduckhunter
Re: sparkly paint??
wow! maybe i should just go with a metallic spray paint. Would this work?
oops!
Re: sparkly paint??
metal flake is exteremly hard to repair...
lets say you do paint it with metal flake........three years down the road the hull gets several dings and chips........
how you gonna fix that?......you cant get matine tex to match metal flake....
the best your gonna do is have spotted hull.....some with flake spots and some with out.....
mtduckhunter
Re: sparkly paint??
thats looks really good!! i think im just gona do that insted.
