  #1
Old May 12th, 2008, 11:26 AM
badjo badjo is offline
Default Mariner 175 Wont Rev in Gear
Hey guys - newbie here,
I got an 88 Champion with a 175 Mariner, just replaced throttle tower and a bunch of little items.
Put the boat in the water yesterday... no leaks!!
But the motor will rev fine in neutral, put it in gear no problems, but when I start to gas it up it will go to about 2k rpm max... it then wants to stall.
I can pull the throttle back and idle around fine.
While the boat was moving I got back and manually moved the throttle body and it did the same thing ... it slowly tries to rev but then starts to stall.
If I leave it in high throttle, it will stall out.
Timing?
Anyone know where there are some online pictures of this motor so I can see if I am missing some kind of timing advance mechanism.
Hard to test this repair out of the water, and my nearest lake is an hour away.
  #2
Old May 19th, 2008, 02:15 PM
Default Re: Mariner 175 Wont Rev in Gear
No replies yet but more info:
The motor will not rev past 2k rpm under a load.
New spark plugs
Jets clean and proper size
I tried manually moving the timing advance arm while under load... advance/retard only bogged.
Gas lines are clear, ball firm.
Just got shocked 6 times running the boat in a tub.. not under load but idling.
When I am in the lake and move the throttle forward in gear the RPMs do not jump around at all... only a rapid bog that will kill the engine if I leave it there for 4 to 5 seconds. No sign of life.
Any test suggestions?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
97-115 mariner wont rev up jondilar Mercury & Mariner Outboards 0 July 15th, 2007 12:10 PM
40hp johnson rd-23 wont rev out in gear nikos73 Johnson & Evinrude Outboards 3 November 20th, 2005 07:39 AM
78 Chrysler 115hp wont go in gear..for. or rev. snowman100 Force & Chrysler Outboards 4 August 15th, 2005 07:32 PM
wont go into reverse in water,1979,175 mariner,cd,6cyl divepat Mercury & Mariner Outboards 1 August 16th, 2002 09:58 AM
60Hp Mariner wont go into gear RobAz Mercury & Mariner Outboards 4 February 6th, 2002 05:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
