just changed oil in foot,is light brown ok?
P psehunter Seaman Apprentice Joined Jan 18, 2008 Messages 33 Apr 8, 2008 #1 just changed oil in foot,is light brown ok?
S steelespike Supreme Mariner Joined Apr 26, 2002 Messages 19,069 Apr 8, 2008 #2 Re: light brown oil If oil was like coffee with cream you have water in the oil.Be sure you use new gaskets on the drain and fill screws run it a few hours and check the lube again.
R rndn Commander Joined May 20, 2007 Messages 2,323 Apr 8, 2008 #3 Re: light brown oil No it's not. I sounds like it had water mixed in with it. How was the oil level? Was it high or did it run out like water? Do you see a leak anywhere?
