  #1
Old May 12th, 2008, 01:35 AM
brunolund brunolund is offline
Default cleaning aluminum hull?
bought a boat in jan. got it running last week. now my hull.
the hull has a buildup of what looks like hard water deposits, but is a PITA to remove. i've tried a wire wheel, a scraper, some hull cleaner from store( i thinbk it's starbrite) but it didn't touch the stuff.
any ideas??? here are some pics.
  #2
Old May 12th, 2008, 02:37 AM
ltoolmanb ltoolmanb is offline
Default Re: cleaning aluminum hull?
I had a 12' aluminum boat that I first cleaned real good with vinegar, then primed with zinc chromate (nasty stuff, wear a resperator) and repainted. From the pic's your alum. hull looks pitted, you might want to mask off the red and primer and paint. Aluminum is tricky though, you have to acid clean it first, (that's why I used the vinegar.) rinse it prime & paint.
good luck!
Lew
  #3
Old May 12th, 2008, 09:25 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
80 grit sand paper on disc grinder, it does look pitted. you may not get it smooth,
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old May 17th, 2008, 08:27 PM
how should i prep it after i grind away the crap? not to familiar with painting alum. which paint and primer to use?
  #5
Old May 18th, 2008, 09:09 AM
joeyplumley's Avatar
joeyplumley joeyplumley is offline
zinc chromate primer is the traditional route. I couldn't find it anywhere - not many places carry it anymore because it's such a health hazard.
I bought a quart of rustoleum's latex aluminum primer for about $8 and brushed it on. It's made to be topcoated with either latex or oil-based after it's dry.
If that was my boat, I'd scrub with vinegar and a soap, rinse, dry, and prime with the rustoleum. Then I'd spray a couple coats of high-build primer, and topcoat with your choice of paint.
__________________
The fleet:
-1979 18'6" Starcraft Super Sport, 1985 Mercury 60hp http://forums.iboats.com/showthread.php?t=260400
-1994 Kawasaki Super Sport X1 (750cc)
-1998 Arctic Cat Tigershark 640L
-Sevylor Voyager 9'2", Tanaka 1.75hp
  #6
Old May 23rd, 2008, 12:22 PM
the metal is not pitted, it has acoating on it that feels like sandpaper. this is what i can't get to come off. a fine wire whell on a die grinder didnot work very well, but it does scrape off in places. it looks like it could be sand, but then why won't it come off? tried vinegar and green starbrite, niether worked, no matter how long i left it on. i took some scrapings and put them in a jar one with vinegar and one with starbrite. after two days, the scraping are still there, same as they came off.
would a strong pressure washer work?
  #7
Old May 23rd, 2008, 04:19 PM
jameskb2 jameskb2 is offline
If it's hard water or mineral deposits, I might try, in a small area as a test, toilet bowl cleaner. Find the "thick" formula, with the highest concentrate of Hydrochloric Acid you can find. I think the Ace Hardware brand is it, around here.
Vinegar is a light acid, but not strong enough to remove hard water stains quickly.
If the toilet bowl cleaner doesn't touch it, then it's something other than mineral deposits more than likely.
  #8
Old May 23rd, 2008, 05:59 PM
86bonito 86bonito is offline
I have the same problem. Boat was left in the water for 2 weeks when it was pulled out I had to scrape all the barnicals off the bottom which left a rough sandpaper like surface. I tried star bright, scoch pad on a drill with commit clenser, oven cleaner, nothing has worked. Tashasdaddy is probably right. I broke down and bought sanding discs at wallmart this morning $3.00 for 5. Good luck! If you try the toilet bowl cleaner please post and let me know if it works before I spend a few hours on my back.
  #9
Old May 23rd, 2008, 06:39 PM
Just tried the 80 grit on the drill took it right off. However I would feel more comfortable doing it by hand. It may have to wait untill winter the fishing is starting to get hot. I'll pull the motor and the center councle off and figure out a way to get the boat off the trailer and flip her over. 18 1/2 foot starcraft 800-900 lbs. from what I've read. I do not want to do any structural dammage to the sides trying to roll it. Then hand sand and paint.
  #10
Old May 24th, 2008, 07:55 PM
i'm using a cupped wire wheel on a drill. it takes it down to the alum. then i'll prime and paint. however i'm going to attempt this on the trailer.
  #11
Old May 24th, 2008, 08:55 PM
Quote:
Originally Posted by 86bonito View Post
...and figure out a way to get the boat off the trailer and flip her over. 18 1/2 foot starcraft 800-900 lbs. from what I've read. I do not want to do any structural dammage to the sides trying to roll it...
My 18.5' Starcraft is gutted, and I flip it by myself when painting or working on the bottom. Grab rails etc are removed of course, or they'd get squished.
I would guess the hull by itself weighs only around 200 lbs since I can lift it when sitting flat, upside down on the ground.
__________________
The fleet:
  #12
Old May 24th, 2008, 08:57 PM
Muriatic acid (from Home Depot, etc in the pool dept) is hydrochloric acid, most likely in a higher concentration. Just thought I'd mention in case you need to buy a lot of it.
__________________
The fleet:
  #13
Old May 24th, 2008, 09:45 PM
Coors Coors is offline
I think it's called csr, from Ace, etc. I get mineral deposits in the house, and that stuff dissolves it.
  #14
Old May 25th, 2008, 10:21 AM
Quote:
Sheesh, yeah, I should have thought of that! It's used to clean tile and masonry faces of mortar or grout. Why that didn't come to mind?
I dunno! (I'm getting old?)
  #15
Old May 25th, 2008, 10:24 AM
Quote:
Never tried CSR. I've heard of it though, from TV ads?
Maybe I will try that in the future for similar work.
  #16
Old May 25th, 2008, 11:28 AM
samo_ott's Avatar
samo_ott samo_ott is offline
Up here it's called CLR. Probably the same stuff.
__________________
Steve.
  #17
Old May 25th, 2008, 11:32 AM
Just went and looked to see what I used last time. Lime Away.
That delicate little screen/aerator on the faucet? Soak for 30 min, all deposits gone.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Cleaning Aluminum Joey One Non-Repair Outboard Discussions 9 September 8th, 2009 08:32 AM
1992 Aluminum Boat needs a good cleaning of the Aluminum Hull What works best?? sigarmsp226 Boat Topics and Questions (not engine topics) 10 December 15th, 2007 07:35 AM
Under 18' Which is best fiberglass hull or aluminum hull? monoshock Boat Topics and Questions (not engine topics) 12 July 11th, 2005 08:08 PM
Cleaning aluminum hull Denis Kansier, Sr. Boat Restoration and Building 2 October 20th, 2003 12:16 PM
Cleaning Aluminum huffer Non-Repair Outboard Discussions 1 July 9th, 2002 10:25 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
