Re: settling an arguement
While I don't disagree with Joe Reeves, who has forgotten more about JohnnyRudes than I will ever know, I am still inclined to not second guess the guys who designed and built them.
The Johnson Service Manual, Tenth Edition, Page 81, second paragraph:
Our Engineering Department has, after long research and evaluation developed a ratio of 1 part oil to 24 parts gasoline by volume as best suited for the efficient lubrication of Johnson motors and economy of operation.
It goes on for another page explaining the risks of using any other ratio and the damage that may occur. Then, on page 82, at the end of the section on Lubrication and Fuel Blending, it adds this note:
NOTE
"Starting with 1964 motors, Johnson's recommended oil and gasoline mixture is 1 part oil to 50 parts gasoline. Before the 50:1 mixture can be used, the recommended break-in procedure must be followed using the 24:1 mixture."
Being the grandson of an engineer and philosopher, I was told many times that when an engineer tells you how to maintain and use his/her designed product there are many factors that affect those instructions that are beyond the user or technician understanding.
What Joe explains seems to me to make sense, but if Johnson manufactured engines that they believed could be safely run on 50:1 before 1964, why did they specifically exclude them in the Service Manual?
So, in conclusion, if it is a 1957 Johnson, use 24:1.
