I Have A 1994 115 Hp Johnson, Have A Few Issues With Shifting That Just Have Gotton A Bit Worse. Engine Has Been Able To Start When It Is Gear For A While, Not The Major Issue Right Now Though. I Cant Get It To Shift Out Of Foward, It Was Having Problens Shifting From Neutral To Foward (had To Jiggle The Handle A Bit And Play With The Neutral Button). Then Problems From Foward To Reverse (would Stay In Foward Would Hit Neutral Though). Now Just Stays In Foward Even When Starting (never Hits Neutral Or Reverse). I Read A Few Posts Here And Checked The Linkages At The Engine, Disconnected The One For Reverse And Was Able To Manually Shift Into Reverse. Now I Am Stuck...is It The Actual Shfter That Is Busted (the Neutral Button Doesn't Seen To Go In Like It Used To) Or The Cable....or Something Else I Don't Even Know About?? Any Help/advice Is Welcome!!! Thanks
