  #1
Old May 10th, 2008, 12:28 PM
Todd Dryer Todd Dryer is offline
Default 1984 Bayliner Capri Side Panel removal
Does anyone have any advice to removing a side panel on my Bayliner. I have to replace the steering cables and can't seem to figure out how to remove the vinyl panels. I have removed a couple of up front screws but the panel seems to be attached along the top and I see no way to release it. Does it slide up ?? Am I missing hidden screws or bolts ?? Thanks
  #2
Old May 11th, 2008, 12:27 AM
Mark42's Avatar
Mark42 Mark42 is offline
Default Re: 1984 Bayliner Capri Side Panel removal
Some of the screws have a vinyl colored plastic cap covering them. The cap is just slightly larger than the head of the screw. Have you uncovered and removed these screws?
On my 85 Capri Cuddy, the pannels are held on with screws, you just have to find them all.
I also plan on replacing the steering cable. I noticed that the cable is run "the long way" to the transom, not straight along, but up high above the outboard control, then down near the rear seat, then back up under the gunnel and around to the transom. My guess is that my 1600 Capri Cuddy has a much shorter distance from helm to motor, and Bayliner probably buys the cables in bulk cheap in one size, and snakes them around on short boats to make them fit. Can't think of any other reason for having a cable that is obviously 5 feet or so longer than it needs to be in the boat. When I buy a replacement, it will run straight along the hull and not snake around.
__________________
1985 Bayliner 1600 Capri Cuddy, 1965 MFG Niagara Custom. >> MFG Video<<. >> MFG Project<< >>Bayliner Hard Top Project<< >>Bayliner Fuel Tank Project<<
  #3
Old May 11th, 2008, 04:37 PM
Side Panel has been removed. I was unaware of those hidden screws. Thanks. Now the real job begins. I need to put in a new Morse Teleflex rack and cable steering setup. Any advice before I begin ......?
  #4
Old May 28th, 2008, 03:28 PM
dave kirk dave kirk is offline
so glad i read this. i have an '84 capri cuddy 16footer. my steering is getting a little harder so i may need to change out the cable. i did notice the caps on the screws & think i'll be ok.
Q: will grease help along the connecting bar & cable?
Q: if new cable is needed, is this a difficult jo?
Thanks dave
  #5
Old May 28th, 2008, 03:29 PM
Q: if new cable is needed, is this a difficult job?
Thanks dave
  #6
Old June 13th, 2008, 04:03 PM
Mark42's Avatar
Thanks dave
I didn't have to remove any pannels. Just pull the carpet back in the top of the gunnel to expose the bundled wire harness and steering cable. Cut off all the tie wraps. In the rear, remove the speaker and reach in the hole to cut off the tie wraps or reach in around the side. Remove battery and reach up to cut off the tie wraps. Be very careful not to cut any wires or the speedo tube. Then take a sawz-all and cut off the cable right near the outboard. Disconnect the cable at the steering helm, and pull the cable out from the helm. Without the motor end on the cable, it should slide right out. Put new tie wraps on the wires. Remove outboard to remove the part of the cable in the through-tube.
Measure and order a shorter cable that runs from helm under motor controls, right past speaker and out rubber boot. Don't bother getting one long enough to snake all the way up to the top of the gunnel by side glass. Install new cable in through tube and snake through the cabin up to the helm. Re mount motor.
No, you cannot replace the cable without removing the motor, or at least sliding it all the way to one side.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
19' Bayliner 1984 Capri / Volvo Penta Motor trucku Bayliner Boats 16 October 5th, 2007 04:21 PM
97 Bayliner Capri 1950 instrument panel question ksliger Bayliner Boats 3 September 19th, 2007 07:50 PM
1984 bayliner 17 foot capri... Where to get cover tarp? ck85abc3 Boat Topics and Questions (not engine topics) 8 May 29th, 2007 08:42 PM
1988 Bayliner 15 foot Capri Side Cushions 2000vikings Boat Restoration and Building 2 April 8th, 2007 07:03 PM
owner's manual for 86 bayliner capri same as 85 capri? massimofinance Boat Restoration and Building 3 December 5th, 2004 09:35 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
